Across International supplies laboratory equipment in the areas of heat treatment and material processing for universities, research facilities, and labs worldwide. We have over 30 years of industr...
Read More
Innovative vacuum & atmosphere coating & hydrogen brazing retort furnace manufacturer focused on high efficiency & performance, reliable designs that are easy and low cost to operate &a...
Read More
INEX supplies Si-SiC radiant tubes with 2X heat release, exceptionally long life and energy savings. Many heat-treaters already increase furnace productivity by 25% & more with lower operating ...
Read More
The ITS Customer Support Services Division is staffed with highly trained field technicians and parts specialists, and offer field installations, equipment relocation, retrofit and repairs, startup...
Read More
Ipsen designs and manufactures industrial atmosphere and vacuum heat-treating systems, supervisory controls and predictive maintenance software platforms for multiple industries, including Aerospac...
Read More
Surface Combustion's primary goal is to assist our customers in keeping downtime to a minimum through the immediate response of our in-house Aftermarket Parts, Rebuild, and Customer Service Departm...
Read More
