Many nonferrous alloys in pure form have (relatively) low strength and cannot be used in applications where resistance to deformation and fracture are important.
The passivation of stainless steel is a post-heat-treatment process with the end goal of improving corrosion resistance by restoring the protective oxide film on the part surface.
Hydrogen is one of the highest-volume gases consumed by the heat-treat industry and is used for a broad range of process applications because of its unique chemical and physical properties.
definitions HT, passivate
