This Website Uses Cookies
By closing this message or continuing to use our site, you agree to our cookie policy. Learn More
Industrial Heating logo
search
cart
facebook twitter linkedin youtube
  • Sign In
  • Create Account
  • Sign Out
  • My Account
  • EMAGAZINE
    • eMagazine
    • Archive Issues
    • Contact Us
    • Advertise
    • Subscribe
  • NEWS
  • FEATURED
    • IH Daily
    • IH MagEzine
    • Web Exclusives
    • The History of Industrial Heating
    • Heat Treatment Processes
    • Thermal Processing Products
    • Top 10 Heat-Treated Holiday Gifts
  • TOPICS
    • Additive Manufacturing / 3D Printing
    • Ceramics & Refractories / Insulation
    • Combustion & Burners
    • Heat Treating
    • Heat & Corrosion Resistant Materials / Composites
    • Induction Heat Treating
    • Industrial Gases & Atmospheres
    • Materials Characterization & Testing
    • Melting / Forming / Joining
    • Process Control & Instrumentation
    • Sintering / Powder Metallurgy
    • Vacuum / Surface Treatments
  • COLUMNS
    • Editorial
    • The Heat Treat Doctor
    • Federal Triangle
    • Academic Pulse
    • International – Brazil
    • Reshoring Initiative
    • Washington Watch
    • Technical Talk
    • Thermal Processing Matters
  • BLOG
    • Dan Herring - Heat Treatment
    • David Pye - Metallurgy
    • Dan Kay - Brazing
    • Debbie Aliya - Failure Analysis
    • Thomas Joseph - Intellectual Property
    • Omar Nashashibi – Government
    • Reed Miller – Thermal Processing
  • DIRECTORIES
    • Equipment Buyers Guide
    • IH Buyers Guide eBook
    • Commercial Heat Treat Capabilities Directory
    • Aftermarket Parts & Services Directory
    • FORGE Buyers Guide
    • FORGE Buyers Guide eBook
    • Take a Tour
  • MULTIMEDIA
    • Podcasts
      • Interviewing the Author
      • Heat Treat Technical Talk
    • Videos
    • Webinars
    • eBooks
  • EVENTS
    • Meetings & Trade Shows
    • Heat Treat Show
    • Heating & Cooling
  • CE CENTER
  • MORE
    • Classifieds
    • White Papers
    • Industrial Heating Bookstore
    • Organizations
    • FORGE Magazine
    • Market Research
    • Custom Content & Marketing Services
Home » Topics » Commentary/Columns » Technical Talk
Technical Talk
Technical Talk RSS Feed RSS
figure one
Technical Talk
Bainite and How it is Formed
David Pye
David Pye
May 8, 2023
One Comment
Bainite is a phase in steel that can be created by heating the steel up to an austenitic temperature followed by a designed cooling procedure.
Read More
graph 1
Technical Talk
Vacuum Furnace Burnout Cycles for Aluminum Brazing
Dan Kay
Dan Kay
April 17, 2023
No Comments
Someone recently suggested to their aluminum-brazing client that they should conduct a high-temperature burnout cycle in their vacuum furnace by “heating the furnace to 1600°F to ensure that all the oxides are removed.
Read More
Figure one
Technical Talk
Diagnosing Hydrogen Embrittlement in Hardened Steel Parts
Debbie Aliya
Debbie Aliya
March 6, 2023
No Comments
Some people think they can tell if a part broke due to hydrogen embrittlement by looking at it. This is not correct. The timing of the crack is only one of the key factors that needs to be documented if hydrogen embrittlement is suspected.
Read More
comprasion
Technical Talk
Time, Temperature and Transformation
David Pye
David Pye
February 9, 2023
No Comments
Time waits for no man. Time cannot be saved. Time only moves on, even as we speak. The process temperature will determine what microscopic transformation will occur (including grain growth). Transformation is the resulting metallurgical effects of the process time and temperature selected.
Read More
Figure one
Technical Talk
Apply BFM to Only One Side of a Joint Being Brazed
Dan Kay
Dan Kay
January 18, 2023
No Comments
Brazing filler metal (BFM) is available in a variety of different forms, shapes and sizes, such as wire, rod, paste, sheet, foil, preforms and cladding.
Read More
Debbie Aliya
Technical Talk
How About Some Critical Thinking?
Debbie Aliya
Debbie Aliya
December 14, 2022
No Comments
Most of us have heard someone complaining, “There’s a lack of critical thinking here.” But what do they usually really mean? If we stop for a moment, perhaps we will realize that it often means, “I disagree with your conclusion.” But does that mean that the thought processes used were inadequate?
Read More
Figure 4
Technical Talk
Temperature Uniformity
David Pye
David Pye
November 9, 2022
No Comments
Temperature uniformity within a furnace can be defined as: “a uniform temperature set to operate within a specific tolerance band to create conditions under which a final uniform resulting metallurgy will be accomplished in the treated component.”
Read More
figure two
Technical Talk
BFM Powder Used in Making Braze Paste
Dan Kay
Dan Kay
October 18, 2022
No Comments
A common way to create brazing filler metal (BFM) powder is by melting the raw metallic ingredients for the BFM in a large melting pot using induction heating and then pouring that alloyed liquid metal through a specialized atomization nozzle.
Read More
Tree of knowledge
Technical Talk
Education in Failure Analysis (and Life)
Debbie Aliya
Debbie Aliya
September 12, 2022
One Comment
For those of us who would like to gain high-level competence in any profession, it’s critical to explore many of the branches of the tree of knowledge. If you are helping others solve technical problems, deep knowledge in the advertised subject matter is required. Communication skills serve as one example of a crucial additional area of required expertise.
Read More
optical microscope
Technical Talk
Hardness Testing and Surface Preparation
David Pye
David Pye
August 15, 2022
One Comment
Hardness testing determines the success of the heat-treatment procedure and the material’s response to that heat treatment.
Read More
Previous 1 2 3 Next
Subscribe For Free!
  • eMagazine Issues
  • eNewsletters
  • Manage My Preferences
  • Online Registration
  • Subscription Customer Service
More Videos
Popular Stories
figure one
Hardness Measurement Method
Finding the Right Case-Hardness Measurement Method
Induction Heating
Induction Heating is a Green Technology
Events
January 1, 2030
Webinar Sponsorship Information
For webinar sponsorship information, visit www.bnpevents.com/webinars or email webinars@bnpmedia.com.
View All Submit An Event
Poll
Has additive manufacturing had any impact on your business?
View Results Poll Archive
Products
Practical Heat Treating: Basic Principles
See More Products
IH Classifieds
Get our new eMagazine delivered to your inbox every month.
Stay in the know on the latest thermal-processing news and information.
SUBSCRIBE TODAY!
  • Want More?
    • Industry News
    • eNewsletter
    • Connect
  • Resources
    • Industry Links
    • Manufacturing Group
    • List Rental
    • Survey And Sample
  • Privacy
    • PRIVACY POLICY
    • TERMS & CONDITIONS
    • DO NOT SELL MY PERSONAL INFORMATION
    • PRIVACY REQUEST
    • ACCESSIBILITY
    • UPDATE MY PREFERENCES
Copyright ©2023. All Rights Reserved BNP Media.
Design, CMS, Hosting & Web Development :: ePublishing
