Wear, corrosion and fatigue properties are
strongly dependent on surface quality and its modifications. Thermochemical
methods such as gas and plasma nitriding allow for enhancement of these
properties in most severely loaded (mechanically and/or chemically) applications
without causing any changes in dimensions of the treated objects.
Nitriding is a process that involves diffusing nitrogen
into a ferrous part’s surface. The result is a part with increased surface
hardness, wear and corrosion resistance, anti-galling properties and improved
fatigue strength.
Vacuum heat treatment followed by oil quenching
and double tempering produces a microstructure with high strength and excellent
toughness, ideal for applications involving heavy loading and fatigue.
This month, we focus on
the materials used. Previous print articles have addressed the basics of the
process (April) and the details of the process chemistry (May).
