Busch Vacuum Solutions USA, a Virginia Beach, Va.-based manufacturer of vacuum pumps, blowers, compressors and systems, acquired Jennings Associates Inc., a distributor for new equipment, maintenance and repair for vacuum pumps, blowers and heat exchangers. The acquisition of Jennings’ vacuum pump, blower and service portion of the business furthers Busch’s long-term goal of providing better technical and service support for customers in the eastern central region of the United States.
Retech, part of the SECO/WARWICK Group, is completing an order with Livnica Preciznih Odlivaka (LPO), a foundry in Serbia, for a vacuum induction melting (VIM) furnace. The 50-kg furnace will be used for high-speed precision investment casting. Precision casting using the lost-wax process will significantly improve and accelerate the foundry’s production capabilities. A great advantage of the furnace is the very short time between loading the mold and the start of casting. Parts manufactured at LPO are installed in engines used in the commercial aviation industry.
Ipsen was awarded an order from SITES Medical for two 2-bar vacuum furnaces. The furnaces will be used for orthopedic implant processing, such as stress relieving Ti and CoCr components, as well as diffusion bonding of Ti and CoCr implants. Each TurboTreater has a work zone size of 24 inches wide x 24 inches high x 36 inches deep with an all-metal hot zone. SITES Medical is an orthopedic technology development company that invents and de-risks new technologies and collaborates with OEMs to bring them to market. The furnaces will help the Columbia City, Ind.-based company accommodate increased volume resulting from growth in business.
Innovative deposition techniques that leverage the unique characteristics of yttrium aluminum garnet (YAG) are enabling realization of this material’s performance advantages as a thermal-barrier coating at ultrahigh temperatures.
TAV Vacuum Furnaces, together with its U.S. group company Furnacare Inc., supplied a horizontal vacuum brazing furnace to a U.S.-based engineering company that specializes in a wide range of brazing services. The furnace, which has useful dimensions of 48 inches wide x 30 inches high x 48 inches deep, offers an advanced solution for high-vacuum brazing of aluminum components. It has a maximum operating temperature of 1150°F (621°C) and a maximum gross charge of 500 pounds.
Aerospace Material Specification 2750 (AMS 2750) is the main pyrometry specification that provides the requirements for the calibration and testing of thermal-processing equipment.
This column will discuss a brief comparison between low- to high-temperature-deposition methods of surface-modification treatments in relation to thermal-diffusion treatments.
Here is a complete list of all the feature articles – by topic – that appeared in Industrial Heating in 2020. The month each article appeared in is included. All articles are hyperlinked for your convenience.
Germany’s Karlsruhe Institute of Technology (KIT) will use a vertical vacuum retort furnace supplied by SECO/WARWICK for high-vacuum annealing of gyrotron components. The furnace will have a water jacket with a compact integrated cooling system. When open, it is 12 meters high, and the diameter of the usable space is 1.8 meters. KIT also required a specific level of high vacuum that will be achieved with the use of a cryogenic pump. According to SECO/WARWICK, the vacuum furnace will enable researchers at KIT to achieve a very clean process under vacuum and, thanks to its dimensions, will enable them to develop gyrotrons with larger dimensions.
