Author_herring
Dan Herring is president of THE HERRING GROUP Inc., which specializes in consulting services (heat treatment and metallurgy) and technical services (industrial education/training and process/equipment assistance. He is also a research associate professor at the Illinois Institute of Technology/Thermal Processing Technology Center.
Common Rockwell Hardness Testing Problems (part 2)
December 14, 2011
Question:
Could you explain the most common problems when conducting Rockwell hardness testing?
Answer:
Here are the remaining four problems and tips from last week’s blog (in no particular order):
5. Readings taken too close together will give false (higher) hardness readings.
a. Indentations should be three diameters apart.
6. The indenter is damaged (chipped or cracked diamonds or flattened balls) and will produce false readings.
a. Periodically remove the indenter from the hardness tester and inspect the tip using a low-power magnification (10-50X) such as a stereomicroscope or loop to check for damage. Flattened balls are sometimes difficult to detect unless you inspect all surfaces – often at an angle.
7. Parts that are not properly supported will give false readings.
a. Large and irregularly shaped parts need to be well supported. Parts that move, even slightly during the test, produce a false reading – even if that reading falls within the desired hardness range.
b. Changing the anvil to one that keeps the part stationary using the variety that should be available with your tester.
c. Additional outside support (such as a Steady-Rest®) may also be required.
8. The sample being tested being too thin will yield false readings.
a. The material being tested should have a thickness at least 10 times the depth of the indentation. Minimum acceptable thicknesses can be found in ASTM E18 Tables 4 and 5.
b. Special (prehardened) anvils can be used when hardness testing thin sheet or foil material.
Sugestion
Andy Steven
January 4, 2012
It is no surprise that operators often can be the source of problems in Rockwell hardness testing. Training operators to be competent in the discipline means that they should understand the theory of the test method, the proper operation of the instruments they are responsible for running, and the surface preparation requirements and fixturing techniques for the parts they are responsible for testing. By gaining an understanding of these areas, the operator will acquire sensitivity to the test method and the abstract thinking required to prevent some of these problems from occurring. In most cases, training operators properly once will eliminate rework, and will help to protect the investment made in the testing instrument. any ways just in order to share knowledge i am i have my site regarding hope you will like this: http://www.intechnde.com/store/hardness-testing.html
Reading error
azhar
April 21, 2012
When we reading taken, hardness tester always give plus reading, not as per test sample, Example: our test peace hardness is 95 HRB, and machine give us 103HRB every time. How we can solve this problem, and what is the reasion?
Reading error
Dan Herring
April 22, 2012
Dear Azhar: Thank you for your question. If I understand your question, you are testing either a hardness calibration block or test piece of known hardness and you are seeing readings above what they should be. This is an indication that your hardness tester needs to be calibrated. If you have another hardness tester available to you, you should try to take readings on this other machine to make sure that you are not introducing other forms of error into the testing method.
2013 Energy-Saver Update
This section showcases the latest energy-saving products and technologies available to the thermal-processing industry. It can also serve as an informational guide for ways to help your company reduce its carbon footprint, which will ultimately lead to reduced energy costs - the ultimate goal of every manufacturer in today’s business environment.
In this month's podcast, Dan Herring and IH Editor Reed Miller discuss the loading of parts. Sponsored By: Praxair
Facebook IconUpdated Facebook IconYoutube IconLinkedin Icon
